8/5/2009 12:43 PM | |
Posts: 152 Rating:
hi i have many questions today, for this 6XV1 850 0AH10,industrial ethernet ITP GP cable the inside cables are comparatively bigger than other CAT5 cable, so they are not inserting inside RJ 45 jack, does this cable has some special JACKs. and also does it has some special Jack protectors , (i do not what it is called the green one in below picture for prefabricated CAT5 cable) how it is possible to insert the pair cables inside normal RJ 45 jacks. please have look on attachment. i hope somebody will help me thanks a lot in advance sun , (novice to job) Attachmentethernetcable_cmp.pdf (227 Downloads) |
8/5/2009 2:41 PM | |
Posts: 5822 Rating:
Dear Sun, well, I guess this is what many do, but there is a slight difference between a Patch Cable like a CAT 5 or CAT 6 like the 6XV1850-* and a ITP cable. AttachmentIndustrial_Ethernet_FC-Plug.pdf (238 Downloads) |
8/5/2009 3:52 PM | ||||||||||||||||||||||||||||
Posts: 5822 Rating:
Dear Sun, I hope one of these two Gentlemen will be able to help you:
If you mention that you have the Plug based upon the IK PI Catalogue they should find it and should figure out if this Plug is available to you. Best regards J_Bell |
8/5/2009 3:58 PM | |
Posts: 152 Rating:
Dear J_Bell |
