3/19/2018 5:09 PM | |
Joined: 7/30/2012 Last visit: 2/8/2023 Posts: 334 Rating:
Hello I'm using CU320-2PN In that i'm using torque control with encode in vector control mode i need to switch between speed /torque mode using P1501 In speed control i'm using Jog signal to rotate motor but its not working Standard Telegram 2-4/4 In torque control its working fine but facing over speed fault upto some Nm its working fine Before in servo mode i used same logic its worked fine Refer attachments AttachmentTorqueControl.zip (34 Downloads) |
