6/26/2013 10:08 PM | |
Joined: 12/29/2011 Last visit: 8/9/2023 Posts: 39 Rating: (9) |
In the TSM screen using the select key (Looks like a horse shoe) in the spindle direction field you can select spindle positioning mode and then input an angle for the spindle to position/move where you would normally input the spindle speed. Perhaps this will work better. Attached is an explanation from the Shopturn Operating and Programming Manual. all the best Mr_Al
AttachmentSpindlePosition.pdf (96 Downloads) |
6/27/2013 3:08 PM | |
Joined: 12/12/2006 Last visit: 9/21/2023 Posts: 21 Rating: (0) |
Thanks a lot! In a few minutes I will check this. It looks like the answer I need. |
6/27/2013 5:34 PM | |
Thanks! As Arquimedes said: EUREKA! |
