2/5/2011 8:36 AM | |
Posts: 2964 Rating:
Hi... You can short 56 and 14 and see movement is getting stopped....check the setpoint is voltage is cablepropely ..... You can controll the drift though the parameter P093..... and check? Have look on this document https://www.automation.siemens.com/doconweb/content.asp?item=12884&cd=sinumerik_simodrive_04_2010_e&scope=all Alarm list is attached for the reference.... Regards, Ekalavya Attachment611A_SP FAULT DETAILS.pdf (223 Downloads) |
2/17/2011 5:46 AM | |
Posts: 2964 Rating:
Hello... Could you check the version information on the card? try using p51 / p151=10 and check? Hope fully it should happen.... Regards, Ekalavya |
