4/16/2009 10:35 AM | |
Posts: 73 Rating:
Hello Have a look at the following link, in the manual "Extended drive functions" section 2.3 http://www.automation.siemens.com/doconweb/content.asp?item=9603&cd=sinumerik_simodrive_10_2008_e&scope=all Basically you can use the same drive but switch the motor in via contactors. It is important that the contactors are switched correctly Good luck |
