9/30/2008 8:58 PM | |||
Posts: 487 Rating: (45) |
To access WinCC DB from external application, you will need the following package
Also check the following links for some info https://www.automation.siemens.com/hmi/html_76/products/software/wincc_optionen/connectivity-pack.htm https://mall.automation.siemens.com/DE/guest/content.asp?display=B&aktTab=1&lang=en&nodeID=10016160 |
10/2/2008 7:07 PM | |
Posts: 1275 Rating: (123)
Hi, To complemment what JMJ said: any access by any third party software to WinCC's database requires an additional license. You should check out the ConnectivityPack and IndustrialDataBridge options if you want to export data... However, I noticed you want to display the data in a web browser.. for this you should check the DataMonitor and WebNavigator options. WebNavigator allows the user to control and view the same .pdl files you have in your application, so the WinCC trend controls you already have in your screens could be easily used. As I said, it also allows remote controlling... the DataMonitor option doesn't allow this, so it's cheaper and works if you only need to view the data remotely.. Best regards, Danielle |
