6/21/2007 9:50 AM | |
Posts: 1084 Rating:
Hi, please try logging in a a local admin and see if the problem persist. with regards, Ikkezelf |
6/23/2007 7:48 AM | |
Posts: 86 Rating:
Ikkezelf , Thanks, I did try logging in administrative mode & the problem persists. When I check the SQL2005 server configurator it shows all the server running OK. What is the name of database WinCC is trying to access?Is there any method to ping the database from outside? Will appreciate any help. Thanks, Techy |
6/26/2007 9:36 AM | |
Posts: 1084 Rating:
Thanks Dec! have an older version installed here and didn't knew that it was changed. with regards, Ikkezelf |
6/26/2007 3:30 PM | |
Posts: 1084 Rating:
Hi, Maybe just a reinstall of wincc will help you out |
