3/8/2012 12:22 PM | |
Posts: 3037 Rating:
Hello, You can find more about SQL database with WinCC flexible in the followings links. You should test the example of the following link on your computer. Does apear the same behaviour? How do you log tags in an SQL database and read them out again with WinCC flexible? How do you access an SQL database in WinCC flexible via a script? Tweety |
3/8/2012 1:02 PM | |
Posts: 35 Rating:
following that example i've made the sql database...i how no clue why it doesn't work after i restart the runtime... |
3/8/2012 3:19 PM | |
Posts: 3037 Rating:
Hello, Do you use the function "StopRuntime"to close the runtime? Tweety |
3/9/2012 3:01 PM | |
Posts: 3037 Rating:
Hello, In the following link you can find more information of how to uninstall an instance of SQL server. How to uninstall an instance of SQL Server 2005 manuallyTweety |
