7/26/2019 3:48 PM | |
Joined: 8/31/2005 Last visit: 1/23/2023 Posts: 2194 Rating:
Hello, Even if you wrote you read a lot of documents, I want to advise to look at https://support.industry.siemens.com/cs/ww/en/view/109486133 specally chapters 2 and 4.2 Did you set Bit 10 in STW2_ENC (see Chapter 4.2.1)? If you want to use a TechnologyObject, this handles several things like control and status words for you. |
7/26/2019 5:09 PM | |
Ok, I didn't notice so far the TO counting & measurement is not available in the S7-1200. So, you are right, you have to do it manually. This manual should help: https://support.industry.siemens.com/cs/ww/en/view/59709820 Chapters 2 and 5 |
7/27/2019 9:08 AM | |
Joined: 2/8/2018 Last visit: 1/7/2023 Posts: 59 Rating:
Thanks for manual miami I will make all the necessary adjustments for the TM and revert how it works |
