5/18/2009 6:12 PM | |
Posts: 3 Rating: (0) |
Hello, I already got the solution. You should change your DCOM Settings for OPC.SimaticNET. Use identify with "this user" instead of interactive user. Your Service should start up with the same user. To do that, change the properties of your service startup user. Another thing that you should take care is that your service is started in manual and added to the configuration console startup definitions. The attached screen shots should help you. Good Luck AttachmentOPCSimaticService.zip (229 Downloads) |
5/19/2009 9:07 AM | |
Hi MPVilao, thank you very much for your prompt help I'm going to apply your suggestions !!! |
5/20/2009 1:41 PM | |
Joined: 9/1/2005 Last visit: 1/17/2025 Posts: 4114 Rating: (195) |
Closed, because discussion exists twice. The other thread is published with the subject Simatic NET OPC server running as windows servicewithin the same conference. Best regards CS Moderator |
