11/23/2017 1:34 PM | |
Posts: 35 Rating: (0) |
Hello, Thank you |
11/23/2017 2:12 PM | |
Joined: 9/27/2006 Last visit: 4/18/2024 Posts: 12256 Rating: (2664) |
Hello hoss; The last version of Step 5 (v7.2) installs on Win XP: https://support.industry.siemens.com/cs/fr/en/view/9860493 For installation on higher versions of Windows OS, you should consider a VM configuration. There are a few threads on the forum discussing this subject, for example: And you might like this discussion from another forum: http://www.plctalk.net/qanda/showthread.php?t=56747 Hope this helps, Daniel Chartier |
11/23/2017 2:16 PM | |
Joined: 7/9/2015 Last visit: 4/18/2024 Posts: 3807 Rating: (554) |
Hi, no this will not work - you will need Windows XP STEP 5 V7.2 - Delivery ReleaseRegards, Towome |
11/28/2017 7:27 AM | |
Joined: 6/19/2017 Last visit: 4/18/2024 Posts: 7951 Rating: (162) |
New question published by hoss12 is split to a separate thread with the subject Cable to connect Step 5 and CPU 102U . Best regards |
