3/2/2013 2:58 PM | |
Posts: 56 Rating:
Dear Experts Good day … I’m using TIA Portal software V11 SP2 My PC has OS / W7 Pro 32 bit / I can’t create any new project because always I get the following error message The application has encountered a problem & needs to close
Would you like to restart the application? ( please check the attached file ) I have tried to re-install the SIMATIC STEP 7 Basic V11 SP2 software again, but I got always the same problem … ??? Please advice … Thank u for your time …
AttachmentTIA.zip (50 Downloads) |
3/2/2013 8:37 PM | |
Hello, There are several updates for SP2. The latest update is update 5. Did you run this update after the installation of SP2? You can get the latest update here: http://support.automation.siemens.com/WW/view/en/58112582 |
Best regards |
