11/7/2008 4:18 PM | |
Posts: 2348 Rating:
Maybe you can try SP3... but not sure http://support.automation.siemens.com/WW/view/en/21953245 |
12/1/2008 11:00 AM | |
Hello S.S.D.D., you better should not install SP3 because it is not tested and released to install a newer ServicePack of a part of PCS7. To answer your question where you can get the HFs... The only way to get a Hotfix is to contact the Simatic Hotline because only Servicepacks are published in the internet for download. You can open a Support Request and it should be no problem to get the HF7 if you tell the supporter that you only need this HF to install your Software. Cumu |
Learn more about visualization - visit the HMI courses of Siemens AG! |
