12/11/2008 11:36 AM | |
Joined: 9/27/2006 Last visit: 5/29/2023 Posts: 12024 Rating:
Hello heff; This point has been discussed a few times on the forum already, for example here: The closest you could do this in Step 7 would be an FB with a multi-instance DB. This is because each instance of a timer structure must be uniquely identified in the user program, which you cannot do in a UDT. Hope this helps, Daniel Chartier |
