5/1/2014 12:09 PM | |
Posts: 5225 Rating:
[smile] Boy.. you do like doing it with all-Siemens products, don't you? The PLC will be fine. The power supply: If the power output was okay for the S7-200's it will work here too. |
Last edited by: William B. at: 5/1/2014 2:58 PMNOTE: The S7-1200 is powered the same way as the S7-200. It does not have to have a special power supply unit as some of the S7-300/400/1500 uses. |
