11/3/2021 3:29 PM | |
Joined: 6/11/2019 Last visit: 12/1/2024 Posts: 2331 Rating: (103) |
An oscilloscope or a frequency analyzer might be able to help. But just try a stronger power supply. Ella_68 |
11/3/2021 3:30 PM | |
Joined: 3/30/2020 Last visit: 12/2/2024 Posts: 4990 Rating: (1016) |
Assuming the insertion of the fuse was like having a switch closing.. The description sounds like inrush current. There is a spike of consumption when a device is switched on. This is not always documented well. You may easily see that there is some piece of electronics that pulls more than the supplied power when those were switched off for a while (perhaps as long as 15 minutes). Switching off/on repeatedly will eventually charge the capacitors enough in the electronic device so that the power supply can keep it on. [https://en.wikipedia.org/wiki/Inrush_current] Ella_68 said it first.. get a bigger power supply that can handle the switch on. |
Last edited by: qwazee at: 11/03/2021 15:31:30Activities of this user is voluntary. There is no obligation or liability placed on this user. Though optional, your 'please' and 'thank you' is highly valued. |
