3/12/2012 9:40 AM | |
Joined: 9/28/2005 Last visit: 5/2/2023 Posts: 2957 Rating:
Hi, You can't load full string into ACCU as it is 32-bits wide. You can work with pointers if you like. Also check check this System Software for S7-300/400 System and Standard Functions Volume 1 and Volume 2 chapter 26 about manipulation of STRING data types. |
Best regards, |
3/12/2012 9:48 AM | |
Posts: 13 Rating:
Can you give mean example how I can use a pointer Thanks..
