9/21/2006 1:16 PM | |
Posts: 3149 Rating:
[quote user="kedar"]What is the use of structure tags with respect to faceplates? Are the structure tags used only in conjunction with faceplates? Hi, you can use structure tag without faceplates as well. They are quite nice e.g. if your machine has drives and you prefer a kind of modular programming on your S7-CPU. Normally I use a separate faceplate e.g. for drive1, drive2,... drive1.current drive1.poweron drive.2.poweron drive2.current.... http://support.automation.siemens.com/WW/view/en/23690358 http://support.automation.siemens.com/WW/view/en/22533646 http://support.automation.siemens.com/WW/view/en/23130772 nemo |
