10/7/2019 3:13 PM | |
Joined: 4/20/2017 Last visit: 1/23/2023 Posts: 75 Rating:
Hi guys.. Did you solve this problem or do you have some solution for that? I have same problem. I have CPU315-2 PN/DP programmed in TIA Portal 13 SP2 and book size CU320 with line feed and three S120s. I tried to used siemens FBs for this.. SINA_PARA_S for read / write parameters but with no success because I have HMI Lite 6.2 in this project and there is problem with used WRREC versions.. It is not possible to compile project.. So then I tried to go by different way.. With using of WR_REC and RD_REC.. But I stuck on WR_REC ret_val 16#8093... I don't know what I am doing wrong... ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 10/07/2019 17:07:15New subject after splitting |
10/7/2019 3:14 PM | |
10/7/2019 5:08 PM | |
Joined: 8/21/2014 Last visit: 2/2/2023 Posts: 698 Rating:
Closed because question is posted multiple times. Please use: trying to use SFC 58 to calibrate encoder on S120 |
