12/19/2015 1:17 PM | |
Joined: 11/29/2011 Last visit: 8/24/2023 Posts: 1347 Rating:
Hi, Have a look at the SIMATIC S7-300 CPU 31xC and CPU 31x: Technical specifications under chapter "5.1.3 Retentivity of memory objects". The retentivity options are different in CPU firmware versions as you can see in the manual. Check out the referenced pages in the manual to find out what caused the data loss. You can also upload the diagnostic buffer of the CPU so we can have a look at what could cause the issue.(Reset/PowerOFF/MemoryReset) Keep in mind the "NON-Retain" property in DB's in question. I hope I could help! |
Last edited by: MicroMan at: 12/19/2015 1:42:27 PMLast edited by: MicroMan at: 12/20/2015 8:24:11 PM- What you read here, please check with manuals and your requirements. |
12/31/2015 11:45 AM | |
Joined: 5/15/2010 Last visit: 5/1/2023 Posts: 170 Rating:
Hi, I have studied the manual. I have found that there is a option in DB to have retentive memory or to have non retentive memory. I checked my program and found that the DB is con figured for retentive operation. What can be another reason? Regards, Vinit
12/31/2015 12:46 PM | |
Hi, Retentivity behavior of S7-300 CPU 31x and complete devices C7-6xx with MMC What is the effect of the STEP 7 function "Copy RAM to ROM"? |
Last edited by: MicroMan at: 12/31/2015 6:11:09 PMAdded info about MRES - What you read here, please check with manuals and your requirements. |
12/31/2015 9:08 PM | |
Joined: 3/21/2006 Last visit: 7/12/2023 Posts: 10221 Rating:
https://support.industry.siemens.com/cs/ww/en/view/18645578 https://support.industry.siemens.com/cs/ww/en/view/837001 Best regards, Hristo Mihalev |
