7/11/2019 8:09 AM | |
Joined: 10/18/2006 Last visit: 2/25/2025 Posts: 120 Rating:
Hi EduGimenoG, if you prefer using a OPC server KEPware will always be a good choice, esp. because of its wide variety of available interface to PLC vendors. But What is your plan after you measured your data? How will you analyze them? Do you know ibaPDA? It is a powerfull data acquisition software. Connection Omron and Siemens will be possible. And the Analyzing tool ibaAnalyzer is free of charge, so build analysis and reports is no problem. It is just a suggestion :-) (look at my signature, who I am working for) Please ask your local dealer for a free demo. |
iba AG - Data Acquisition and Analysis the way it should be |
7/12/2019 4:16 AM | |
Joined: 9/9/2015 Last visit: 3/24/2025 Posts: 732 Rating:
Dear EduGimenoG, Let me share my comments, 1. What is the model of Omron PLC? For what I know, Omron PLC is a very basic PLC. Based on what I know, OPC Server is normally built in SCADA software. I do not think Omron PLC has this OPC UA communication protocol. 2. Kepware LinkMaster is commonly used, it can adapt to a different type of communication and consolidate into one. But do you have so many OPC capability PLC in your plant? 3. In my opinion, you can have a PLC programmed with the Root Cause Matrix list, make a PLC-PLC communication with all the Omron PLC, then buy an HMI to display the Root Cause Matrix. If your Omron PLC has OPC capabilities, it will be the best, because no program changes needed for the PLC. Hope I understand your request correctly and hope my two cents is helpful for you. |
Please give me 5 stars Rating if my post is helpful for you. :) |
7/15/2019 5:30 PM | |
Yea, I believe Web application is a better choice. OPC, yes, you can choose to have OPC comm, provided your plant is OPC enabled. Need to check those HMI coming with OPC server capabilities. For Siemens, I guess Mindsphere, XHQ, or OS Web Options might be able to meet your requirement. (depend). Mindsphere - https://support.industry.siemens.com/cs/ww/en/view/109755908 XHQ - https://support.industry.siemens.com/cs/ww/en/view/109766404 OS Web Option - https://support.industry.siemens.com/cs/ww/en/view/109766404 What I think is, being able to convert all the data in your plant and identify the root cause matrix is the hardest part. To integrate them into web-based, it will be quite easy once the root cause matrix is cleared. The difficult part will be, if your current PLC doesn't ready for all these stuff, to have this system built, the challenge is very high. |
