11/20/2018 8:16 PM | |
Posts: 2826 Rating:
Hello.
The task is possible. See the attachment - study the right hand side of the timing graph. For this example, two absolute move blocks are used. The same can be done with a high absolute move target set. Your idea will also work where the first absolute move block is a velocity motion instead. BR Attachmenttiming-diagram.pdf (300 Downloads) |
