6/8/2022 9:05 PM | |
Joined: 2/17/2020 Last visit: 4/21/2025 Posts: 1250 Rating:
Hi Madjid_5713, You can do this, for example, by using a ScreenWindow and changing the screen within the ScreenWindow based on the change of the Tag. This can be done using a script. For more information about scripting see the following FAQ: SIMATIC WinCC Unified - Tips and Tricks for Scripting (JavaScript) As an example, you can use an I/O field in your layout screen and attach the PLC Tag to the process value of the I/O field. If the value of the Tag changes, the script for switching the screens will be executed. |
A rating will be well appreciated. |
