4/28/2020 1:21 PM | |
Hello try this one in the TIA Portal Engineering System: https://support.industry.siemens.com/cs/de/en/view/109778709 Then download the Runtime Project again and do the test in Simulation or Rutime. Bye Murof |
5/6/2020 3:17 PM | |
Posts: 2 Rating:
Hi! Have you solved this problem? I have exactly the same problem. I think Windows updates are to blame. |
