4/1/2008 11:07 AM | |||||
Posts: 82 Rating: (6) |
DEAR ALL, I AM DOING A SMALL PROJECT WHERE THERE IS A LOT OF DATA TRANSFER ON RS485. THERE IS HEATING SYSTEM & RADAR GUAGING SYSTEM WHICH IS ON RS485. BUT INCASE OF LOADING ARM, IT IS ABOUT 3.5KM FROM PLC. SO WE ARE USING FIBER OPTIC. I HAVE SELECTED
WILL THIS BE SUITABLE FOR ALL THE DATA COMMUNICATIONS. I AM USING SERIAL TO FIBER OPTIC CONVETER FOR LOADING ARM. MOREOVERCAN I USE UTP TO FO (ETHERNET TO FIBER OPTIC) CONVERTER. IF YES, CAN I CONNECT DIRECTLY TO MY ETHERNET SWITCH? CAN I GET THE DATA WITH MY EXISTING CONFIGURATION? I AM USING
NOTE: I AM ATTACHING THE SYSTEM CONFIGURATION FOR CLEAR UNDRESTANDING. THANKS IN ADVANCE. YOUR ADVICE WILL BE REALLY APPRECIATED. REGARDS PLC ENGINEER AttachmentM-Overview Model.pdf (255 Downloads) |
