7/13/2023 11:55 AM | |
Hello AutoGen_538887 What do you mean exactly? WInCC Advanced gives a systemalarm if the connection to the PLC is established and also if its down. (140000, 140001) you can show an alarm window or alarm view with system alarms to see it. Or you use something like this: https://support.industry.siemens.com/cs/de/en/view/109481628 Bye Murof |
