3/12/2007 1:51 PM | |
Posts: 24 Rating:
Hello, I am a beginner using S5, I need to modify an existing program on a S5. I add a new process block you will find attached. The problem begin when I add segment 2, 3 and 4 with timers, when I transfer to PLC the PLC show a failure. That I am doing wrong ? S5-100U AttachmentPB003_LS.zip (66 Downloads) |
3/12/2007 7:41 PM | |
Posts: 24 Rating:
Ok , thanks I solved it,I deleted the DW outputs !! Regards Fernando |
