8/18/2011 8:03 PM | |
Joined: 1/28/2009 Last visit: 9/25/2023 Posts: 6822 Rating:
Check the following cases: Why is the MMC no longer recognized by SIMATIC devices after it has been formatted in a third-party device? With MMC (Micro Memory Card) slotted, why does the STOP LED blink on the SIMATIC S7-300 CPU? About the LEDs, if the CPU is in the run mode and SF is active, diagnostics buffer of the CPU will help.The buffer will give us unambiguous clues on the issue. Best regards |
