9/4/2024 12:30 PM | |
Joined: 5/6/2008 Last visit: 4/11/2025 Posts: 13 Rating:
Hi. What to use instead of "system info" driver in old wincc scada in wincc professional ? Thanks in advance. |
9/4/2024 1:44 PM | |
Joined: 2/17/2020 Last visit: 4/25/2025 Posts: 1251 Rating:
Hi, I believe you could follow the "8. Diagnostics with WinCC Professional" section (from page 40) from the following FAQ to achieve a similar functionality: Diagnostic of SIMATIC IPCs (with IPC DiagBase, IPC DiagMonitor, WinCC (TIA Portal) or WinCC V7) |
A rating will be well appreciated. |
