11/1/2013 9:23 PM | |
Joined: 9/27/2006 Last visit: 9/9/2024 Posts: 12282 Rating: (2682)
Hello Gabriel; Please look at Mr. Bill West's reply to the following thread, and follow the links provided. Notice that you can open the links in Spanish, if that makes things easier for you. Memory CPU 317-2 PN/DP Basically, once the Work memory (memoria de trabajo) is full, you cannot expand it, add to it, make it bigger. You can try reviewing your code, remove unused functions, make use of multi-instance DBs whenever possible, generally try to make your logic more compact. or you can swith to a higher-level of PLC, a CPU 317-2PN/DP for example. Or look for a more recent version of your CPU 315, the CPU 315-2AH14 has384 kB of work memory; your present one only has 128 kB: 6ES7315-2EH14-0AB0 CPU315-2 PN/DP, 384 KB Hope this helps, Daniel Chartier |
