7/31/2008 3:25 PM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating:
Hi, did you read the info in this manual? -> http://support.automation.siemens.com/WW/view/en/18797552 Chapter 9.1 Check your parameter in your project from the recipe view > Data record . There must be a wrong value. Under this Link there you can found a good info about "Recipe" -> http://support.automation.siemens.com/WW/view/en/23901413 regards, |
8/7/2008 4:47 PM | |
Joined: 7/5/2006 Last visit: 1/11/2023 Posts: 166 Rating:
no reason for this system message? maybe it's a bug ? nobody can answer? thanks |
