4/11/2025 10:27 AM | |
Joined: 1/21/2013 Last visit: 4/22/2025 Posts: 3768 Rating:
Hi andreagold99, You cannot change the behavior of this system-defined dialog. However, depending on the version of your system, you can create your own login dialog using the ChangeUser method. Kind regards |
4/11/2025 11:35 AM | |
Joined: 12/12/2019 Last visit: 4/18/2025 Posts: 7 Rating:
Ok, thank's for the answer! I use Tia V20: do you think that this "bug" is fixed in the next update o release? |
4/11/2025 8:37 PM | |
Hi andreagold99, I am pretty sure that allowing the user to change their password is not a bug. Kind regards |
4/15/2025 10:21 AM | |
Hi andreagold99,
No, any user can change their password. Kind regards |
