10/24/2016 7:12 AM | |
Posts: 1 Rating: (0) |
Hi Good Peoples, Thanks for the chance for me to expose my case here. I need a system to monitor and control with centralized and locally of all distributed PS7-300 in each of 10 substations. In each substation, i need to put the industrial PC for control & monitoring of local operator. Then in a head office, i need a central operator for control and monitor. The communication is utilize fiber optic. What kind of software from siemens i can use? Does S7-300 have multimaster system? Or i have to use such as wincc open architecture which need all distributed server at each substation and head office? Any advice, will be highly appreciated Thanks a lot Best regard Aziz ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 10/24/2016 1:26:55 PMNew subject after splitting |
10/24/2016 1:34 PM | |
Joined: 3/5/2014 Last visit: 8/5/2022 Posts: 5521 Rating: (1054) |
Hi Azis, I recomment you to contact Siemens technical consulting/Engineering Support you will find a local contact in Siemens Contact Database
I don´t think that this can be done in this forum. hope this helps, regards, |
FCK WAR! |
