9/1/2014 8:24 AM | |
Posts: 1368 Rating:
Hello, there are no screens added- Can you attach some informations? Thanks |
9/1/2014 9:10 AM | |
Posts: 5 Rating:
Sorry... here you can see, Many thanks
9/1/2014 11:04 AM | |
Posts: 1368 Rating:
From CPU firmware V2.0 STEP 7 (TIA-Portal) provides for the SIMATIC S7-1200 the T_CONFIG. If you use CPU >2.0 it should work. Please check the HW ID again. The hardware ID is also stored in the system constants of the PLC tags. A faq to T_CONFIG is here http://support.automation.siemens.com/WW/view/de/75795361 |
