3/20/2019 4:31 PM | |
Hello Sparisse in this FAQ it is shown how to connect to a SQL Server Database: https://support.industry.siemens.com/cs/ww/en/view/61883659 It also worked in WinCC Professional. To display the Data in the WinCC you need a Datagrid Control or you use the recipe System (UserArchive) for this Topic. Bye Murof |
Last edited by: Murof at: 3/20/2019 4:31:16 PMIf this Information really helps, you could use the Rate function |
11/20/2019 12:43 PM | |
Posts: 7 Rating:
I've checked but it doesn't work in WinCC pro. because there is no place to insert DSN name(ODBC)! do you know the solution?
