7/13/2013 12:57 AM | |
Posts: 10 Rating:
Thanks for replying hdrosseini! in these images you'll see my structures with some diferent names, but the same idea. I also printed the popup and the calling faceplate with their linking mechanism and their events. Hope it helps me!
Attachmentcalling_faceplate_dynamization.pdf (269 Downloads) |
7/13/2013 1:57 PM | |
Posts: 123 Rating:
With WinCC flexible it is not possible to multiplex structure tags. https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&objId=24171756&nodeid0=24359292&load=treecontent&lang=enThis is probably also true for WinCC (Advanced) in TIA Portal ![]() If you really want to use multiplexing with stucture tags, then do it in the controller.
7/15/2013 2:04 PM | |
Posts: 123 Rating:
Really? It doesn't for me. |
