6/10/2009 6:25 PM | |
Joined: 1/4/2008 Last visit: 3/8/2023 Posts: 703 Rating:
Hello, I'm afraid it's not possible to use the concatenation with the direct tag connection, you should use the script for both - the reading and also writing. For writing ta tags you also have to define some separator to let the script know how to divide the text. Can you please explain what are you trying to do? Maybe we could suggest you some another solution or ifis possible to use the scriptthen couldprovide a detailed information for you. Regards Sydney in attachment I tried to create the scripts which could do that job... (WinCC V6.0 SP3a because it's just installed on PC I'm working on now) AttachmentPdl.zip (51 Downloads) |
6/11/2009 4:21 PM | |
Posts: 178 Rating:
A number of good options mentioned already. Just as an alternalive. |
