4/30/2008 5:57 AM | |
Posts: 487 Rating:
The specs I found are For the TP177A Nr of alarms 1000 Nr tags 500 Nr screen 250 For TP177B Nr of alarms 2000 Nr tags 1000 Nr screen 500 Have a look at the following link see the technical specifications Anycase if I have to pick a OP/TP my limit for using a TP177A would be 500 alarms , 250 tags , 50 screen.if I need more ( in design stage) then I would take a bigger OP/TP.But having said that the TP177A is the only one that you can turn sideways ( portrait ) but has no clock . Greetings Eric |
