9/18/2023 3:05 PM | |
Joined: 7/19/2022 Last visit: 4/23/2025 Posts: 436 Rating:
Hello pratik7332, With a WinCC Comfort or Basic you can do logging but to CSV type files, with a WinCC Advanced you could do it via script and store data in a script although not very often because it would penalize the performance and finally the WinCC Professional which would be the appropriate one for data archiving in SQL. Don't forget Unified, which does allow SQL for archiving |
