5/14/2007 1:27 PM | |
Posts: 1275 Rating: (123)
Hi, Are you sure you've re-generated the server package after your last modification? Is there anything in your logs? Best regards, Danielle |
5/14/2007 1:32 PM | |
Hi, You should take a look at this and this threads. Best regards, Danielle |
5/14/2007 3:08 PM | |
Hi, Did you configure the Archive Configuration properly? It seems that your system may just be taking to long to load the packages... Try moving your archives from the original folder, so that as long as WinCC is concerned you have no archives. Activate runtime and see if the system can load the archives then. Look at this FAQ. If the selection of archive / tag is done through a script, take a look at this. You're sure your computer has enough resources, right? And there is nothing in your logs? Check the CPU usage while WinCC is loading the trends... and look at this. Best regards, Danielle |
Last edited by: Danielle at: 14.05.2007 15:11Last edited by: Danielle at: 14.05.2007 15:10 |
