3/8/2023 2:07 PM | |
Joined: 5/16/2020 Last visit: 3/8/2023 Posts: 1 Rating:
I have the same problem with WINCC UNIFIED 18 , tags are read without problems , but can't write in any way (Textbox / Script etc ... this happens with Bool , Integers from PC simulation and from Phisical HMI Panel) The DB is ok (i check the same variables with a NOT Unified panel and works) so the problem is only for UNIFIED panels. During test i have found a strange behavior of monitoring of DB if i try to modify current value of one variable is opened yhe popup with random values ... i don't know if is related to this problem or is one general problem o Version 18 .... ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/09/2023 07:52:04New subject after splitting |
