8/31/2006 3:34 PM | |
Posts: 3149 Rating: (171)
Hi have you seen this: http://support.automation.siemens.com/WW/view/en/22016422 http://support.automation.siemens.com/WW/view/en/13681075 nemo |
9/1/2006 5:09 PM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating: (151)
Found these two faqs : http://support.automation.siemens.com/WW/view/en/775166 http://support.automation.siemens.com/WW/view/en/22834940 The first shows how to get symbols from the Symbol Editor into WinCC. The second shows how to import datablock items into WinCC Flexible. Not exactly what you want as you are using WinCC and not WinCC Flexible but I mention it for two reasons : 1) There seems to sophisticated way to export a datablock ! 2) Maybe you could adapt the Excel sheet to work with a WinCC format ? Sorry I cannot come up with a better answer. Possibly worth checking in the S7 forum to see if there is an easy way to export a datablock to a text file. |
9/5/2006 10:20 AM | |
Nice solution Reuben[8)] |
