11/23/2013 4:14 AM | |
Joined: 9/2/2012 Last visit: 3/14/2025 Posts: 711 Rating:
Hai, what you assigned at connection settings of wincc flexible project ?? plc adres? hmi adress? slot number? mode of communication? is they matching with your actual configuration ?? Simply you can try one more thing-- insert hmi station in your simatic manager project, configure as your hmi. then under connection browse your CP node instaed of entering the parameter... regards vipz Attachmenthmi.pdf (143 Downloads) |
