1/27/2012 1:42 AM | |
Posts: 4 Rating:
I need to connecta modemTC65with a controllerS71200, this is possible?,suchthatany successcan help me? |
2/1/2012 5:58 AM | |
Joined: 8/31/2010 Last visit: 2/8/2025 Posts: 1524 Rating:
Hello rubenponce, Why don't you try with CP1242-7 for your requirement? It may not be wise if you have TC65 already with you. But with the CP1242-7, you can easily do with both of your requirement. For more info on CP1242-7, check here - 6GK7242-7KX30-0XE0 |
Like it? Rate it! |
2/1/2012 4:39 PM | |
Hello rubenponce, I don't know the feasibility of your requirement. Even if you connect the TC65 using RS232 to S7-1200, but don't know if you can club the TC65 for teleservice in TIA Portal v11. May be if you try / get to know on it's feasibilty you can share it here. Apart from TC65, Sending SMS viz MD 720 is possible but again teleservice with the same is ruled out. Sending SMS with MD-720 and S7-1200 |
Like it? Rate it! |
2/4/2012 12:23 AM | |
Posts: 4 Rating:
Thanks for your suggestion, we will testthe equipment andpost theresults ifwe havesuccess. |
