7/11/2013 12:53 PM | |
Posts: 3 Rating:
Hi, there was similar topichttps://www.automation.siemens.com/NL/tf/WW/en/Posts/88265but there wasnt explained how created code in C# forestablish communiction and for exchange data between PC and PLC viaTCON, TDISCON, TRECV, TSEND. So i want to ask if someone can help me or show right way. Or if someone know more easy way to comunicated via TCON, TDISCON, TRECV, TSEND with PC i will be happy :-) Thanks Daniel
7/12/2013 10:24 AM | |
Posts: 3 Rating:
ok thanks :-) but on side PC how change status of some memory in PLC? by sending BLOCKS? but how i can send block from C#?
7/18/2013 1:32 PM | |
Joined: 11/21/2007 Last visit: 3/16/2025 Posts: 2326 Rating:
Hi |
There is no such thing as the last bug in a program |
7/19/2013 7:57 AM | |
Posts: 3 Rating:
Thanks for testing software and helps. OPC i cant use because in that way i must buy licence for OPC Server but i need free visualization and controling PLC from PC. Rated Xyou wrote that iwill send only a byte block via TCP. So is possible to change some details in PLC from PC? for example set output?
