11/26/2008 2:27 PM | |
Posts: 5822 Rating:
Hello Antonius, I would like to whish you good luck with your project. J_Bell |
12/1/2008 4:43 PM | |
Posts: 5822 Rating:
Hello Antonius, good to know that it works right now. Strange in my mind is that the TCP Connections you mention should have the same function... but well... depending on the Firmware used with the CPU, true. Have you maybe checked this tool yet? Generating the Connection Data for the open TCP/IP Communication using the Open Communication Wizard Best regards J_Bell |
