7/1/2024 1:32 PM | |
Joined: 10/3/2008 Last visit: 8/28/2024 Posts: 961 Rating: (124)
Hi, which version of MB_REDCL do you use? And do you have a wireshark trace? Wüstenräuber |
7/2/2024 4:41 PM | |
Hi, you should use the hotfix of this block: https://support.industry.siemens.com/cs/ww/en/view/109763972 When CP1 shows "Active connection establishment in progress/closed" it seems, that the connection establishment to the partner is not okay. Wireshark shows, that the connection is established, the telegram to the partner is sent, but the partner doesn't respond. So, check the communication partner and - if possible - reset the connection/instance from this side. Wüstenräuber |
