2/8/2018 1:40 PM | |
Joined: 11/15/2017 Last visit: 3/12/2025 Posts: 78 Rating:
Hello all, I'm using the program provided by Siemens: TCP File Server for S7 Controllerbut can't get the windows application working. It's not displaying the local network adapter IP or port. I've allowed the program in the windows firewall and even turned the firewall off. I'm using windows 7 64 bit. I've set an IP adress in the same range of my PLC (S7-1511-1PN) and tried sending a file from the PLC using the set adress. I can ping the PLC and PC from another PC so the network connection itself appears to be ok. Does anyone have experience with the software and know what i'm missing? Kind regards |
Last edited by: Sibrand at: 2/8/2018 1:42:17 PMLast edited by: Jen_Moderator at: 2/8/2018 1:55:44 PMOptimized link. Last edited by: Sibrand at: 2/8/2018 2:04:32 PM |
7/18/2018 4:49 PM | |
Posts: 41 Rating:
Hello Sibrand I also face the same problem. Have you got the issue solved? Please share your experience to help me |
