7/5/2013 7:11 AM | |
Joined: 2/20/2010 Last visit: 2/19/2025 Posts: 104 Rating:
hi, here you are trying to communicate between two different make PLC, for that you need to change protocol from one plc to another for that you need to connect physical protocol converter in between. please follow this link for more detail. click here |
7/5/2013 8:33 AM | |
Joined: 3/18/2008 Last visit: 12/8/2023 Posts: 1750 Rating:
Hello, Here i found similar discussion. Ethernet comunication between AB PLC and Siemens PLC Regarding communication Between Siemens plc & Rockwell Control Logix hope this helps. |
VANDE MATARAM..... |
7/8/2013 8:13 AM | |
Posts: 461 Rating:
Will try echo change & update soon Thanks & Regards, Nelliyan.G |
7/8/2013 8:31 AM | |
Posts: 262 Rating:
Recently in one cement plant we have used Anybus converters, this was recomended to us by UL group who promots profibus internaltional as there was some case study with them, refer the below link:- http://www.ulepl.com/Displayarticle.aspx?art=495&mid=241 AttachmentX-gateway 1_2011.pdf (382 Downloads) |
11/11/2015 2:53 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by Parthiban@batpl is split to a separate thread with the subject Gateway Converter for low price. Best regards |
