5/4/2013 8:11 AM | |
Joined: 12/1/2009 Last visit: 9/5/2024 Posts: 672 Rating: (147) |
Dear engrwaqas05 , I am wondering that nobody else replied to you yet. While your CPU does not restart you should start troubleshooting from thediagnostic entry of the CPU. You can access the diagnostic screenfrom the Menu bar underPLC/PLC Info ISTACK or simply pressShift+F9. The information shown there should give you some more details. If you are not fimilar with trouble shooting on S5 you can take a screen shot and post it here. Two more questions to you. Do you have any EPROM or RAM module installed into the CPU or is thatslot empty? What can you see from the LED's at the CPU? (i.e. RED LED steady on...). We will try to support you but it will take it's time. Best Regards. |
Give us your feedback and show us your respect! |
5/8/2013 3:53 PM | |
Posts: 2 Rating: (0) |
DearTIBI68 Thanks a lot for your quick reply, kindly check the attached pdf file which give almost all answers of your questions for the said problem. Thanks & Regards
Attachmentplc reply for automation.siemens.pdf (311 Downloads) |
5/8/2013 8:05 PM | |
Dear engrwaqas05, |
